chopperdog
- Joined
- Jun 7, 2009
- 71
1988 OMC Cobra, Bayliner Ciera Sunbridge.
Small leak in transom since I bought the boat.
I have some days off, and it's cold outside so I wont' be using the boat. I would like to tackle the transom leak.
I took the drive off, and there is water in the bellows that surround the drive shaft. There is a little rust on the U-joint of the drive shaft.
1.) Is that water normal? If not, what does it indicate? Could it have been just a bad gasket when the outdrive was last put on?
2.) My plan is to remove the gimble housing and transom plate, and take a look at what I need for the transom. Any advice here is appreciated. I can brace the engine away from the transom, giving me plenty of room to work in the bilge, without having to pull the engine.
Does the transom plate just unbolt from the inside, then come apart on the inside and outside of transom?
I'm kinda driving blind here, but willing to tackle it to get it fixed before it warms back up.
Thanks in advance,
Chopperdog
Thanks in advance,
Chopperdog
