Rebuilding trim cylinders on Johnson 110 hp (1988)
Ross Pantano
Does any one know where I can source a spanner wrench to assist me in removing the end caps on the trim cylinders on a Johnson 110 hp? The tilt cylinder operates fine but the two trim cylinders behave like they have glue in them. Maybe an air lock. I did refill the reservoir with hydraulic fluid but little to no help. Any feedback is welcome and appreciated! Thanks in advance.
dingbat
Don't know if this is the exact one you need, but there are number of links to different suppliers.
Have you drain the system and refill? Could be stuff trapped in the control circuits.
Ross Pantano
I will drain it and refill. If that doesn't do it I will rebuild the trim cylinders. Thanks!
