I rebuilt the carbs on a 1987 Merc classic 50(45hp). It idles of for a minuet then stalls. however if I tap the choke when it slows down I can keep it Idleing. Also it only goes 3000rpms at WOT unless I pump the prime ball then it revs up to 5000rpms. Adjusting the mixture does not seem to help. <br /><br />Question 1:<br />How do you set the Carb float level?? I could make no sence of the Merc service manual. Could having the float too tight cause my problem?<br /><br />Question 2:<br />The rebuild kit included 2 diaphragms one of rubber and one of plastic. Should I use one of both. I installed both with plastic over rubber. Could this be the source of my problem??<br /><br />Thanks<br />Patrick
