firecapt13
- Joined
- Mar 13, 2010
- 57
Ok Got everything back together and still have to play with timing but boat idles high around 1500 rpm. Not sure what problem is with timing, I think I have distributor in backwards or cam is 180 out. I had to reverse plug wires to get it to run but it cranked perfect after switching wires except for high idle.
Idle adjustment screw with spring on it does not bottom out. Is the idle adjusted with this screw or the rod mount near back of motor.
Anything else to try
4.3 Mercruiser 1992 with 2bbl carb
