Rebuilt evinrude 115 lack of power
Trooster99
I recently rebuilt my 1991 evinrude 115 but it won’t rev above 3,500 rpm and struggles to get the boat on plane with two people on it. Carbs have been taken apart and cleaned with carb cleaner
Orange / blue stripe wires FROM powerpack going to the TOP coils on both sides ??-----And did you determine the cause of the failure that led to the rebuild ?
Trooster99
Yes they are, it was rebuilt because a ring came apart and tore up the #3 piston
Trooster99
It seems like it would be a fuel problem to me because it runs smooth it just won’t rev up all the way but I could be wrong
What is your compression now ?----Spark on all 4 leads that jumps a gap of 3/8" or more ?----Flywheel key sheared ?----Orifice plugs in carburetor bowls confirmed clean ?----The correct prop for your boat ?
Trooster99
Compression is good couldn’t see anything in any of orifice plugs after spraying carb cleaner through and compressed air, unsure of spark gap or flywheel key will have to check. Prop hasn’t been changed since before rebuild and did fine previously
Sorry I can not look over your shoulder but some simple trouble shooting needs to be done.---What fuel pump are you using ?----All throttle plates going full open ?---Timer base moving for proper spark advance?----This motor's lack of performance should be easy to figure out.
Trooster99
It’s the vro pump with oil tank disconnected gas is mixed at 25:1 per the seloc manual break in procedure throttle plates are opening fully timer base is moving
Faztbullet
Pistons installed correctly? On late model heads the pistons can be reversed and not hit eyebrow recess in head.
Trooster99
Cant find a spark tester but doing drop cylinder test nothing changes when unhooking the number one cylinder coil pack is new and tests good with a multi meter
Testing spark for the 3/8" gap is so easy.----A quick and painless way to diagnose motor issues.
Faztbullet
Did you put in correct sides? Motor will run andf idle with pistons swapped just no power.
