Rebuilt lower unit, wont sit in foreward gear correctly.
Shwinkyyy
Good morning,
I have a 1984 mercury blackmax 150hp. I did a rebuild on lower unit and yesterday after putting in gear oil. I noticed when in foreward gear prop doesnt spin much unless i really throttle her up, and i can grab it while in gear and turn it counterclockwise. I get no ratcheting or any kind of resistance. In revwrse gear i cannot spin by hand in either direction.
Also so you know i did not "shim" the driveshaft when i installed it. Could this be my problem? Or could it be gear shift cables?
Shwinkyyy
So just came back in from checking the shaft, it actually seems fine, gave it some gas and tried to hold the prop shaft, and its spinning good. I guess it doesnt spin much while idling?
