I rebuilt a 1978 Mercruiser 140Hp and now am having problems getting it going.
Compression is 140 on all 4 cylinders, Spark on all four, timing is set ( at least close enough until I get a gun. And the Carburetor has been rebuilt with the float set at 1/2" and float drop at 1 7/8".
What happens is I get the motor running, it will idle for a bit (30 sec max) then die on me. It will also die when I give it throttle.
I know the carb is getting fuel from the pump, but can't tell if it is a lack of fuel or a flooding issue. The factory air/mixture screw setting is 1 1/2 turns from seat but I had better response at 2 1/2 turns.
Where do I go from here?
