Theoutdoorsman
- Joined
- Mar 6, 2003
- 669
I am in the middle of rebuilding my carbs again on my very recently rebuilt 1979 Evinrude 140. So far, I haven't been able to get her past 2000 rpms since the rebuild and I continue to hear this annoying cough at an idle. Compression is at 110 all the way around and even. The link and sync was fine. I had her idling at 4* BTDC as per the service manual and the WOT was set to 24* as per the Joe Reeves meathod. Also, I ensured I was getting good fire, via the spark test with my homemade spark tester, which looked good. (Dazzled my 7 yr old son BTW........LOL) The temperature is holding steady at about 130*. Too, I have purchased a seperate 6 gallon fuel cell to aide in the troubleshooting process. I did noticed, however, that the cowling under the lower carb was covered with fuel and figured I had a float adjusted incorrectly. So I've pulled them off again because I know all the fuel line is brand new with the exception of the "T". Core plugs have been removed and carbs have soaked for about 8 hrs now. So far as I can tell, everthing appears to be very very clean and looked just as clean prior to rebuilding them this time. I even made a visiual inspection of the passages using a flashlight shined down the throat of the carbs and visually inspecting the low/high speed orifice passages, with the orifice plugs removed of course, as well as all other passages. I can see good light through every passage. Am i missing something here? Or is it possible that I simply mis-adjusted the floats? Man I need some serious help here. I really want to get this thing up on plane!!!! Anyone have any advice?............. :'(
