TdLpps
- Joined
- Apr 17, 2008
- 35
Good morning. First post on your sight. The information I received from the forum prior to purchase was invaluable although I haven't found much info on the boat I chose to purchase.
I would describe it as follows:
It is all aluminum and does not have a floor. The rear area includes a bench seat for two or three passengers. There is a small storage area under the rear seating area. The front seats have aluminum framed seat backs riveted to a common bench area. There is a small fore storage compartment with a door hinged from the top. The floor is painted a light blue color and appears to be original. The hull measures exactly 15' from the tip of the bow to the transom rail.
In its current configuration the upper surfaces are natural aluminum. The sides and bottom have been covered in a black bedliner material. The original red paint is still visible in spots on both the upper and lower surfaces. The aft panel is white.
It once had a windshield but that is no longer mounted on the boat and the hardware to mount a bimini style top is present on the upper surface.
The dash has a badly weathered speedometer (I think...the lens is so fogged that the lettering behind is unreadable) and an Evinrude engine start switch and choke switch panel. The previous owner claimed that when he purchased the boat it had the original 35 horsepower Johnson engine, but with the Evinrude engine control panel on the dash, I think that information could be incorrect. It is currently powered by a 1986 Evinrude 40 horsepower unit that seems to run well.
Its condition is sound but aged. My plans include a clean up and semi-restoration. I may return it all to natural aluminum, but my family would prefer a more colorful boat. We will eventually re-install a windshield and bimini top.
The man I purchased it from identified it as a 1965 Naden "Gator". I know it's a Naden, but am unsure of the model because the trailer it came with is a Gator trailer. I have been unable to find any serial number tags on the hull.
We got home from picking it up about 3pm yesterday and spent from that time till sunset cleaning out all the trash and junk and then washing inside the hull.
It's a good, solid, simple old boat anf the family is excited to get it out on the water.
JimMachinery, I have read your threads on your Naden and viewed your restoration progress pictures. Have you been able to find out anything more about the mid-sixties Naden boats? Does anyone else know anything?
Anyway, just wanted to thank everyone who contributed information that helped me in my decision to purchase this boat and look forward to any responses.
