recharging issue- amp overload?
Beaux
I have a 60hp 1996 johnson o/b to which I am currently adding a perko 4 way switch and a deep cell battery for a trolling motor. My concern comes from reading a couple of older postings that talk about never charging a deep cell with anything except a trickle charger. Does my O/B charging system have low enough amp output to prevent damage to the deep cell battery when I am running my motor and switch to recharge the trolling motor battery? I have had this setup on a boat previously, but I never looked to see if there was a regulator between the switch and the deep cell.
steelespike
Re: recharging issue- amp overload?
Charging from your motor is ok but if you <br />troll for hours at a time I dont think it will recharge enough between each time.Its not necessary to trickle charge though that is a good way to to bring any battery back to a complete charge.<br />Roughly speaking 1 hour of use takes 2hours<br />to recharge and so on.
Beaux
Thanks spike.... <br />I just wanted to make sure that I wasnt going to ruin a new battery. As far as charging is concerned... I fish in the marsh and use my trolling motor only to maneuver short distances so it shouldnt be to much drain on the battery. I just use depth finder, lights, trolling motor just enough to need the security of the seperate deep cell. Thanks again
