recirculation help chrysler 70hp-707he
pita482
I replaced the hose from my recirculation system after futher inspection realized there was a check valve in the hose wich way should valve go . the hose goes from the bottom cylinder to the bottom of rec plate , does the flow go from the cyl to the plate or the plate to the cyl??? Thanks for ur help
