recmnds for 2.5" fuel filler hose under my console
wn6ngp
I've got a kenner 18' center console. The filler port is on the center of the console since the tank is under the console. The 2 1/2 hose is getting rotten and leaking so I need to replace it. Problem is that I have been unable to make a replacement hose be the same shape. See my attached photo. So I'm looking for any advice on how to make a new hose take on the right shape. Heating it, put sand in it to keep it from kinking or whatever. Need some ideas. So far all I've accomplished is putting a kink in a new hose and that restricts flow too much.
flashback
That doesn't look like a difficult bend to make, cut your new hose the same length and put it in the bathtub of hot water then install immediately.
Appears the issue is the 2.5 ID, have been able to find 2 3/8
Are you sure on the size of the A2 hose? Most marine fuel tanks are 1-1/2" I'd for gasoline and 2" for diesel. On an 18' boat I would expect it to be 1-1/2"
The A2 hard wall hose is stiff, but simply let it sit in the sun for a bit. There will be a natural curve to the hose from the spool when it was made
airshot
All of my built-in tank fill hoses have been 1 1\2" ID hose, can't say I have saw anything bigger. Replaced my fill hose a couple years back when I replaced the hose to the motor. The fill hose was a little stiff but nothing terrible, was able to make a bend by hand to make final connections with minor difficulty. Make sure everything is double clamped so there will be no leaks.
wn6ngp
My bad. It is 1.5" inner diameter. I've done all kinds of heating even putting it in a gas grill. The tight bend causes a crimp/collapse. Now I'm thinking to run some 1" flexible conduit thru it and then do the bending/heating again. Even the old hose I removed has relaxed its original bend so it doesn't look like a big turn now. The hose I bought has all the same markings as the 35 yr original except its made in Turkey.
wn6ngp
A2 hose is available in several different bend radius. This particular Trident branded hose has a 5.5” bend radius
Yes, I saw that. I didn't take measurements but I suspect to fit it is smaller radius than that. However, since the original hose is the same p/n I figured that I should be able to make it work. Just handling the old hose and the new one feels very much the same. That flexible 3/4" conduit should keep the hose from collasping while I try to form it again. I have to wonder how this was done at the Kenner factory.
They make elbows you can buy.
They also have fuel fillers with elbows on them
They make corrugated A2 hose for really tight bends
dingbat
A 5.5" bend radius is a very small BR for a 1.5" hose.
Wire filled liner... isn't going to collapse
wn6ngp
ok, it doesn't collapse but it kinks when that turn radius is too small and the fuel flow is very slow. The original was made of the same material and somehow the boat shop made a turn that sharp. For now I'll patch the old one and return it to service until I can figure out how to make a replacement work.
Not all A2 hose is the same. Seriously, get the corrugated stuff, or change your fuel fill to one with an elbow
