Re: Recoil Spring
First you get some protective goggles, gloves, and hard-cup. Then you look at the recoil pulley and see the little hole in it? Find a pin or nail or something that will fit through the hole, you will need it in a minute.
Have the rope and center spindle out of the pulley. Put the outer end of the spring over the pin in the housing. Now wind the spring into the housing like coiling up a garden hose. When it is all in there, smear some grease on it. Now for the tricky part--getting the inner end of the spring on it's pin. You can kind of form it so that it is somewhere near the pin and look through the spindle hole as you attempt to line it up. Or, after you've done as many as I have, just stick your hand or a screwdriver in there and do it. Mind you, this is the dangerous method and not recommended.
Once it is hooked up, lube and install the spindle and bolt. Now with the housing laying on the bench, wind the pulley up all the way, then back it off one complete turn (or more as required by next step). Stick that nail in the hole--that will keep it from unwinding. BE CAREFUL..if the pulley gets away from you and goes flying back, it will ruin your new spring!!!
Now you have plenty of time to thread the rope into the pulley and out the snout. Note that there is a pin in the pulley that the first turn of the rope goes behind. Install handle on the rope. Now, holding onto the rope, remove the nail and let the rope recoil slowly.
Breath a deep sigh of relief.
