will be needing a timing light for adjusting my 1986 Mariner 90hp outboard. The motor is a 6 cylinder without distributor but has adjustable timing and advance. I would like the light to have a tach, so not the simplest one but not to complicated and be very bright as the timing has to be done under load with the boat in the water(Yes I will be moving and have a helper with the cowl removed, just a bit scary). Can anyone recomend a good timing light with these features that will not break the bank(about $150).
Thanks
Thanks
