I have a 1980 140HP Johnson on a 17' ski boat. Boat / motor does not get a lot use, approx twice a month during the summer for day trips and skiing. I have always noticed some oil / fuel stains on the the tower housing, just below the cowl after use, not excessive but enough to wonder where this is coming from. This oil / fuel is wet, so I know it is recent. All hoses seem to be OK, clamps are tight, etc. Since the engine does have a lot of down time between use, it requires a lot of priming to get started. Can this be causing fuel leaking out of the carbs / air cleaner? Could it be the type of oil, I use Shell Nautilus, are there oils out there that are cleaner? I use a 50:1 mixture which seems normal. How clean should a 30 year old engine run?
