Recommended High Prof/Synth VS Penzoil Gear mesh IN LU
mrix
Hello all,
I've heard some people say that they prefer Penzoil Gear meth in their lower unit over the high preformance synthetic stuff you get at the boat shop.
I personally am a big fan of penzoil gearmesh - but thats in my cars and truck.
The marine requirements are a little different but if the case is sealed i can't imagine it would be that bad, the thing is very similar to a axle differential.
Comments welcome!
-Mark
Frank Acampora
Re: Recommended High Prof/Synth VS Penzoil Gear mesh IN LU
Yeah, The case is sealed--MAYBE--. Remember: It's always under water. If a seal goes--not uncommon--the small seals on the fill screws tend to leak a little--and a little water gets into the case, the marine lube has more anti-oxidation inhibitors. In fact, you can have a gearcase with a lot of free water in it and as long as you don't open it up, the gears will not rust. Once you open it you must clean and re-lube the gears in a timely manner.
