<<<ESSENTIAL DATA REQUIRED
<<<When posting a question about propellers, you cannot get a reasonable <<<answer unless you provide the following information in your post:
<<< Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
Over revs at 5300 RPM. Recommended is 4200-4600 rpm. Current prop is pretty beat up.
2) Current prop manufacturer, model, aluminum or stainless and as a minimum.
Quicksilver Black Diamond Aluminum. 48-83282845-17p
3) Current prop diameter and pitch (required).
15" diameter, 17 pitch, 3 blades
4) Wide open throttle RPM and speed with an average load (very helpful)
5300 RPM, 44.5 MPH
5) Engine/drive make, model, year, and HP
Mercruiser 5.0LX 1995 205 at prop shaft according to manual
6) Boat make model, year, length and weight
1995 Bayliner 2050, weight is 2550 approx lbs according to booklet. Add 174 lbs of gas at ~28 gallons. Add 550 lbs for wife, 2 kids and myself. Total weight around 3274 lbs.
I want to stick with aluminum for the time being. Boat is used for wakeboarding and tubing. Elevation is mainly just a few hundred feet above sea level. Wondering what my best bet would be for trying next.
Any suggestions on where to start will be much appreciated.
__________________
5300 RPM, 44.5 MPH
__________________
