Recommended Propeller
Sir Ug
What is the recommended OEM propeller for my boat. I have a 1989 17' searay bowrider with 100hp Mariner Outboard engine SN: 0C207542<br /><br />The prop that came with the boat is PN: 48-32750-19. Is this the OEM propeller? I can not find this propeller anywhere.
JB
Re: Recommended Propeller
Howdy Ug.<br /><br />What is your rpm at full throttle?<br /><br />The 19" sounds like a good starting point, but you need to select based on your boat and engine.<br /><br />Click on SEARCH and enter Prop Selection.<br /><br />Good luck. :)
Sir Ug
At full throttle it runs at 5800 rpm at 30mph. Presently a 19 pitch is on the boat. There are two other pitches available for my engine. A 21 and 23. Which do you recommend? Does speed decrease with higher pitch or only RPM ? Hustler props are only 79.99. Are Hustler prop ok and are they complete with hub.
1981Baja
My Hustler prop is allright so far. I bought a 21" and a 23" of the new model ("2005" $89) 2 months ago. I ordered one hub and 2 housings
