Whats up guys
Dumb***** me hooked up the battery cables in reverse for a second, I fixed them and started it up, ran perfect, just like normal, tach worked, which I see looking into some threads is one test to see if the rectifer is blown, but im not sure about the charging, the volt meter on the dash stayed right around 12 which it is normally around 13-14, now could this be the tell tale sign of a rectifer problem? I am picking up a multimeter tomorrow to check the battery, with the engine not started and then with it started, not started should be 12 and started should be around 13.4 correct?
By the way I have an 89 Evinrude 88SPL.
Any help would be great!
Thanks
Doug
Thanks
Doug
