Rectifier 1975 Evinrude 70hp
mav6759
My question is, if the rectifier is bad, can it cause starting problems. I looked at my rectifier this morning and saw some fray wires and the wires were missing it's covering. I tape it up, but the one wire looks like its about to fall off. Does the rectifier have anything to do with starting this motor.
thanks Mav
jimdd810
Re: Rectifier 1975 Evinrude 70hp
What kind of issue is it not turning over or not getting spark?
F_R
A bad rectifier will cause the battery to go dead. A very discharged battery will cause slow cranking speeds. The ignition system won't produce sparks if not cranked fast enough. So, in that case, yes it indirectly affects starting. Otherwise, no.
