rectifier question
i have a j0hnson 140 1984 i replaced the rectifier with a johnson part on the instructions it said to connect the yellow gray wire to the yellow gray wire on the terminal but the part i got has two yellow wires and neither of thrm have a gray wire what should i do
flyingscott
They have stopped putting the stripes on the wires probably to save a nickel. They don't matter anyways just connect them.
Crosbyman
btw if ever you need another rectifier (unregulated) this type should work fine .. just mount it securely with a bolt
this is a simple full wave rectifier (replaces 3 legged ones )
wire yellows on the AC pins and out comes DC ground and +12V
just wire the ground to the engine frame to compete the circuit
https://www.amazon.com/dp/B07H5KNR3D...detail_1?psc=1
cheaper…
https://www.amazon.com/10pcs-Single...cr_arp_d_pdt_img_sims?ie=UTF8#customerReviews
just add some heat shrink over thje pins to insulate and recure them down
flyingscott
That one will not work on a 4 cylinder motor. The V4 uses a liquid cooled rectifier.
Crosbyman
I agree fully. they will not replace specialized applications but for general full wave rectification of AC they should work fine. they do warm so they must be bolted... better yet a small aluminum plate under them will help.
I have actulally used them to merge brake and turn signals into a 2 filament trailer bulb circuits the other being the running filament (parking light) they are dirt cheap compared to fancy " converter modules" for trailers . one module is neede for the left side and one for the right side of the car/truck
notice: upon breaking the flashing turn signal will be overidded by the brake function for a few moments
they even make them with 3 AC inputs for 3 phase rectification
flyingscott
No it should be more than the battery voltage but it wont be by much. 12.8-13.5 depends on your system and the condition of the battery..
