Re: rectifier/ regulator
I replaced the rectifier in my 89'200 Johnson last year. Used Sierra aftermarket rectifier. No purple wire. Instructions said purple was not required. It works fine.<br /><br />Leave the wire, that connected to the old purple, attached to the terminal so it won't short something out. <br /><br />Found out that loose main battery connections are usually the cause of rectifiers going bad.<br /><br />livebaiter
