bighermHK45
- Joined
- Jun 17, 2012
- 92
Can a bad voltage regulator cause idle problems? I tried using a inline spark tester on the number 1 cylinder and the spark tester did not illuminate/flash that I could tell (sunny outside). It definitely was getting spark because I grabbed the wires to make sure I had a solid connection and got zapped. At any rate, with the spark tester hooked up it ran really bad. It runs really bad at idle as it is.
Not sure how the CDMs work in conjunction with the voltage regulator. Can I have a bad CDM and have a good regulator? Is the inverse possible, where the regulator is bad, but the CDMs are operable?
The outboard in question is a: 1999 Mercury 115HP 2 stroke.
Any advice would be appreciated.
