Rectifier? Who knew?
davejohnson
Confession here: I bought my old boat 2 years ago, with a 1977 Mercury 900 inline six on the back...and I knew *nothing* about outboards. Long story short, I got a book and lots of trial and error and busted knuckles, and the motor runs fine now. I've always rotated/charged my batteries out every six or seven trips when they'd run down. I never knew a rectifier existed that was supposed to charge the battery. (yes, I'm retarded). Actually, I'm so much more concerned that the thing runs, that I accepted the battery situation. Well, I ran my meter test on the rectifier today, and it is indeed bad. (Looks bad too). So, do I just replace that little block with the three leads on it, or is there more to replace? And is $25.99 too much for that block? So far, I could only find one online. Thank you.
Laddies
Banned
Re: Rectifier? Who knew?
You can ck the alternator windings (yellow to yellow) and make sure you have continuity if you do then all you need is the rectifier--Bob
molsenice
not knowing any "data" about the motor - make model - hp? Try old mercs.com - grubbs marine - nice folks. Replacing it will help battery
emckelvy
Try Sierra 18-5707, replaces Mercury 62351A1, 62351A2, 816770. Check out the factory part #'s at www.mercurypartsexpress.com and for good deals on Sierra aftermarket parts, www.boatfix.com <br /><br />The Sierra parts pricing query is here:<br /><br /> http://www.boatfix.com/searchsierra.asp <br /><br />You might also search this forum on "Radio Shack" as I believe there have been some discussions on using a Rad Shack rectifier in a marine application; the Rad Shack part is considerably cheaper.<br /><br />HTH............ed
JasonJ
Don't feel too bad, I did the same thing for most of the first season I ran my current rig. Replacing the rectifier fixed it, and I also gained several hundred rpms because those ignition systems really need optimal amounts of juice.
etienne
Dave, thanks for sharing your story, similar situation, trying the Radio Shack route. How did yours turn out?
etienne
Success! Here are the steps:<br /><br />1) remove Merc regulator (unbolt wires & housing)<br /><br />2) pry off metal baseplate & grind smooth.<br /><br />3) drill a countersunk hole in the center of the <br /> plate so a tapered head bolt will sit flush.<br /> <br />4) put thermal grease (from computer store) <br /> between the regulator and the plate<br /><br />5) bolt on the Radio Shack regulator ($5) & <br /> threadlock so it doesn't vibrate loose. <br /><br />6) replace Merc wire terminations with spade type <br /> or solder directly to regulator. Use heat <br /> shrink tubing to protect connections.<br /><br />7) solder negative terminal to motor housing <br /> ground since Radio Shack has 4 leads & Merc <br /> internally connects 2 together.<br /><br />8) put thermal grease on back of base plate & <br /> bolt on using original bolts & holes.<br /><br />Nice to have a fully charged battery without lugging the thing around to charge it!
mnw001
I've used the same bridge rectifier for schack on omc's worked great
