Rectifier
ob
Re: Rectifier
A component that converts stator a/c voltage output to d/c voltage.
AtlDawg
Re: Rectifier
small box or plate that converts ac voltage from stator to dc voltage to charge battery. Don't know what motor you have but Johnson/Rudes are usually located on the left side of motor
MDeVito
Re: Rectifier
I have an evinrude. OK, so the rectifier is similar to a power invertor, so now what is stator?
ob
Re: Rectifier
The stator is a stationary set of windings under the flywheel that generates the voltage for the charging system and a separate set of windings within the same unit for ignition voltage.The voltage is produced by the rotating magnets of the flywheel passing the pickup of the windings.Maybe someone else can elaborate further.
OBJ
Re: Rectifier
Without getting into magnetic lines of flux expanding and collapsing, I think ya' 'splanded it real good ob.
ob
Re: Rectifier
See there,I knew someone could elaborate. :D
MDeVito
Re: Rectifier
You guys are just a wealth of knowledge.....thank you!
