Re: red lever on fuel system(evinrude)
Red lever should be part of the primer solenoid. Normal setting is to have the lever parallel with the solenoid body, or end of the lever pointing towards the end of the solenoid. Turn the lever at a 90 degree angle to solenoid and you have manual choke or a way to feed fogging spray through the valve stem.
