So I'm installing a new deck on our pontoon as the old one has several soft spots due to rotting. I ordered 4 sheets of marine grade plywood. Do I need to put any kind of coating on the underside of the plywood? The top will have new carpet on it so I guessing that the carpet adhesive will take care of it. Also the old deck was attached with elevator bolts. Can I use zinc coated ones or should I try and find stainless steel ones?
