Can anyone tell why a shim was added to the reed stops on the 1979 and up engines but NOT on the 1974 thru 1978 Johnson 9.9 and 15hp? Common sense tells me that the engine will breath better at the top end and possibly get more revs. But it's not recommended to shim the stops on the 1974 thru 1978 motors. Comparing a 1975 motor,(has no shims), to a 1979 motor, (that has shims), I looked up the part numbers for these two motors for reeds, leaf plate, manifold, block, crank, and head, there all the same.
What engineering change did they make to the later engines, to require shimming the reed petal stops?
Thanks, Alby
Thanks, Alby
