Re: reed plate -- 7 1/2 hp. evinrude circa 1957
Unless the reed plate was completely disassembled, it can't go in "backwards". If the reeds themselves have been removed and then reassembled, they may have been put backin backwards, which isn't recommended, but I've seen it done. It's also possible that the reeds may have been put on the wrong side of the plate, but I don't think the manifold could have been reassembled that way. Bottom line - I don't think the reed plate is your problem.<br /><br />If your motor runs out the prime from the tank (about a minute or more at idle) and restarts when you reprime the tank (button near carry handle), then you've got an air leak somewhere, or it's not getting pressure from the crankcase. I've seen some of the rubber flappers on the reed plate deteriorate or stick, but not often. Is the gas cap tight? Tank must build pressure, so cap must be tight.<br /><br />If the motor runs for that minute, then picks up speed for a moment and dies, then think fuel delivery from tank to carb. If it simply runs like crap the whole time and dies of it's own accord for no reason, think gummed up carb.<br /><br />If it sharply picks up and drops off RPM, think ignition problem - could be cracked coils.<br /><br />- Scott
