shakespear
- Joined
- Jul 11, 2001
- 40
Ihave a 1975 merc 50hp 500cc 4 cylinder engine which died at the weekend. started to miss badly then died.<br />stripped carbs with no joy.<br />then noticed that 1x reed valve was broke.<br />have just stripped it down an found reed valve carriers to have broke up (had a bit of luck as a bolt had come free and was floating about in the crank case).<br />reed holders are bolted from out side of crank case and this is where they have broken.any advice welcome please help also now looking for spare reed carriers,reeds,& reed stops. thanks, Will
