1Moredrift
- Joined
- Feb 2, 2004
- 36
I have a 24ft GW Offshore and have notices the rub rail is loose in some spots. I have also noticed that I get water in my bilge and deck on rough days that I believe may be entering through this connection.<br /><br />I was planning to take the rub rail off, and loosen all of the screws attaching the hull to the deck, applying some kind of sealant/adhesive, and retightening all of the screws. Then I would reattach the rubrail, also using some sealant.<br /><br />My questions are:<br /><br />1. is this OK to do or would I be compromising the flexibility of the boat/hull and causing other damage?<br /><br />2. in places where the screw holes are too loose, should I A) uses a thicker gauge screw or B) fill the hole with 5200 and use the same size screws?<br /><br />3. What kind of sealant/adhesive would you recommend?
