Refinish wood floors
mscher
Our antique farm house came with some lame "house for sale", cheap light berber carpet, which is like a stain magnet.<br /><br />Peeking under it near the heat registers, it appears that there is oak flooring throughout, but with a somewhat faded 125 year old finish. <br /><br />We are considering removing the carpet and refinishing the flooring, using a commercial floor sander, etc.<br /><br />We realize that it can be big a messy chore, but when isn't replacing flooring messy?<br /><br />I'm thinking of buying a sander on ebay and reselling when complete.<br /><br />Anybody ever tackle this chore? Any input welcome.<br /><br />Thanks
wajajaja
Re: Refinish wood floors
hi, just had my floors done last week, professionally, i investigated doing it my self, and learned 1 that i wasn't up to fighting a 200lb,5 hp 8" belt sander. these machines can chew up a floor in a heart beat. then you need to be able to crawl around the floors on your knees with a edger. and hand scrapper.<br /> the machine that was use on my floors was rigged with a master vac in the truck, virtually no dust in the house. <br /> where the floor was discolored we used a red oak/or mahogany stain,the other rooms natural.<br /> they used a oil urathane applied with lambswool.<br />the results is beutiful, took 2 days, oh they light sanded between coats. <br /> I bought breakfast and lunch and read the paper, they busted butt and made 1650. 1800 sq ft. <br /> If i rented reasonble equipment from h/depot,and bought sufficent supplies,sandpaper,sander pads,resportorie mask, vacume, ectra, i would have spent 600 bucks and a week of hell doing it. <br /> also, the varnish that is on your floors is likely to rich in lead. dust control is critical if your children want to grow up and do thier own taxes. <br /> go pro and spend about 1.50 a square foot. <br /> laminates are a attractive alternative, but cost a little more. and 100 year old planking has a neat quality too.
wajajaja
Gee I got to remember spell checker, the square footage was about 1200 feet, and the staining was a premium of 240, and if I wanted to break up the job it would have been 150 dollars per room extra, so, go with as much at one time as you can. Travel and set up time was important. <br />Anyone in NJ ill recommend the company 100%
wajajaja
on the berber carpet, which i removed for the refinishing , i had good success with the h depot rug cleaner and oxywash, 24 buck a day, and it will do a whole house,like new.
TELMANMN
Get a book on refinishing wood floors. After reading and still want to do(as is dusty and can put deep gouges if don't keep moving or turn off without raising machine) then is a very satisfying experience. Many good water based finishes around now so much easier to do than before. Have no idea why anyone would cover a wood floor!
timfromfc
There may be a good reason the floor was covered. It could be trashed, so be prepared just in case... Also, if you do refinish the floors, it will be very messy. Plan on doing lots of dusting when it's done. For me, it was worth the extra money to pay someone to do it. Good luck!
CoachHolland
I've done a few of these with my dad and have to say it is possibly one of my least favorite things to do next to tearing out old plaster and putting drywall up in it's place (the plaster part sucks, the drywalling is easy).<br /><br />Like mentioned, you'll need the belt sander and if you aren't careful, you'll gouge your floors. Then a small handheld sander for areas that the belt sander cannot get to. You'd think that was the easy job, but old flooring is tough. The stain on something that old will likely be thick and wood that old will be hard as a rock.<br /><br />Staining this once you're done is easy. Just make sure it is done evenly and you're wiping it down after you're done brushing it on every few minutes. The longer it soaks in, the darker your floors get.<br /><br />Finally, you finish it with a good clear coating sealant to get the shine. Get the quality stuff and make sure that the floors are clean and dry before applying. Otherwise you'll end up like me with a home that the crap is peeling up on you everywhere because some idiot (not me, whoever lived in this house before me) didn't do their work properly. I'm going to have to have the floors redone in several rooms throughout my home because of that *insert not very nice word here* who didn't have a clue.
Bob_VT
I re-finished my hardwood floors about 17 years ago. Ouch! My back hurt for a week! I rended a HEAVY floor sander and edge sander. LOT'S of work and lot's of dust.<br /><br />You can rent the equipment but IMO I would look around for a pro... they usually are worth the money.<br /><br />Usually in an older home (mine is circa 1860) the carpet was used to make the floor warmer. Hardwood in the winter tends to be cold and noisy with echo ability.<br /><br />Good luck with it.<br /><br />Bob
CalicoKid
Check to be sure that you have the thickness left to do a sanding, the floors may have been sanded before and be too thin to do another. I spent a good part of my youth restoring my father's victorian floors both oak and maple. Some of the boards were cupped so bad we had to sand diagonally first just to level the floor out and then proceeded as usual. These floors will never endure another sanding.<br /> On the upstairs floors we chose to strip the finish off the flooring and make any repairs necessary (these were in much better shape) and refinish w/ satin polyurethane. This approach left a very nice result, a great patina and a slightly uneven surface from board to board. The look of originality is intact here whereas the downstairs floors look restored, very nice but they are somehow too smooth considering they were leveled with scrapers when first installed. No sandpaper back then.<br /> If you sand get yourself a good cartridge respirator not those paper dust masks and ventilate the house so that you are pulling dust directly out of the area you're working to the outside.<br /> Stain will likely not be necessary unless your floors are stained from water etc. as wood that old will have darkened up quite a lot.
POINTER94
I have done a few in my day, but I can't add to all the excellent posts above except to say the condition of the floor right now would dictate whether I would do it myself, hire a pro, or cover with carpet. (beware of pet stains) This is not a terribly difficult job but messy and tiresome.<br /><br />Good luck and let us know what you do and how it turns out!!!
skeezx01
here is another approach...forget the sanding, unless the floor is verrrrry uneven and if so something else might be wrong. mix 1/2 and 1/2 mineral spirits and boiled linseed oil, rub into the floor with steel wool, wipe off the excess and let dry for two days then wipe again with terry towels to remove any oil that didn't soak in. then apply gym floor sealant(stain first if color change is desired but i wouldn't suggest it).use a natural bristle brush for the sealant and be careful with the rags from the cleaning process, in a closed container the rags can catch fire! we have used this method in manny homes with good results. this is the way grandma did it on the farm
John Carpenter
I have refinished hardwood floors for over 20 years...mostly gym floors but some residential. What you will need to do depends entirely on the condition of the floor and it's thickness. After pulling the carpet, check the thickness of the wood at a floor register. If it is tongue & groove flooring you will need at least 1/4" of wood above the top of that joint to avoid getting into the nail heads when you sand.<br /><br />If the wood appears to be in good shape with an even color you may be able to "screen & re-coat" instead of sanding. This is done with a regular floor buffer with a 100 grit screen instead of a sander. It is much less aggressive...faster, cheaper, and can yield an excellent result. Typical cost on this is .25 per square foot per coat.<br /><br />If the floor is in bad shape and needs to be sanded....if you have never run a "real" floor sander...don't. You can absolutely destroy a floor in a flash. The price quoted for N.J. is also about right for Ky. A dollar a square foot for sanding and .25 per coat for finishing.
lakelover
You might check this out:<br /><br /> Refinshing Wood Floors <br /><br />I just did mine this summer. Saved lots of money, but it was a lot of hard work. I rented an orbital sander (dusty) and still had to do a lot of hand-sanding and touch up because the boards are cupped (51 years old). The best thing I did was to use water-based polyurethane, it doesn't smell too bad and dries for recoating real quick, in a few hours.<br /><br />It came out looking great, but it's worth repeating, it's a LOT of work. I'm not sure if I would do it again :rolleyes: .
Mdude
I'm with Relentless. I installed and sanded/finished hardwood floors professionaly for many years. It's difficult to get good results without the pro equipment, but there is a serious "slight of hand" with using the drum sander and edger. By that, I mean that it takes quite a while to develop the technique and if you don't have the knack for it, you will cause yourself problems. You will need to sand the cross grain marks of the edger to a point that you won't be able to see them with a bright light showing from the side. The edger can only cut in a circular pattern and if you don't get those sanding scratches up before you apply a new stain, your shoddy workmanship will make itself manifest and be immortalized for all observers to see in the future. So you'll have to work the grits from 80 - 100 - 150 - 180 and finish with 220. That's a LOT of work. As a general rule, when you apply a new stain, the darker the color of the stain, the more unforgiving the stain is about showing sanding scratches that you didn't get cleaned up. If you stick with very light colored stains, you can get away with a rougher surface and your boo boos won't show unless someone wants to get down on the knees and go over it with a magnifying glass. Minwax Provincial is a very forgiving stain, but on the last several floors I did, 3 were white oak and we used no stain at all. White oak looks fabulous without any stain. The others were red oak and I don't like to go stainless on red oak. It gets too bright and looks a little harsh. So I tone it down with Minwax Natural. It gives it a nice honey look and is very very forgiving of sanding scratches.<br /><br />Also, you said the floor is some 125 years old. Are you serious? Most floors I've ever done that age were pine. God I HATE pine! Regardless of wood, on any floor, beware of a floor that is old enough that porousity of the wood has become abnormal. Dry rot or other decay causes older wood to not want to sand evenly or take a stain evenly even though the floor may look perfectly sound at first inspection. Sometimes on old floors, you'll see large areas that are uneffected by father time, but then you'll run into an area where the floor appears to be sound but rot spores have eaten just enough of it away that it will gulp your stain down like greedy kids sucking free cokes. If you try to use a stain, you'll end up with dark places and light places and it will look like total trash. For that reason, on those occasions that I've actually agreed to refinish an antique floor, I explained in urgent terms that this job would NOT be a magazine show piece and whatever we had when we finished was what the customer would have to live with like it or not. I would NEVER EVER put any kind of stain on an old floor except Minwax Natural. Again if it was a white oak floor, I'd wouldn't even stain it at all. I'd put on a coat of Porter Twin Seal and 2 coats of satin poly. Sand each coat with 220 grit on a jitterbug enough to scuff up the surface for the next coat. Also, I use a 4" china brisle brush and I do NOT pat the side of the can like a painter does because that puts bubble in the finish that may or not flow out. I clean the brush with mineral spirits. Do NOT thin your sealer or poly. That's a NO NO. Use them straight out of the can.<br /><br />If the floor is relatively new, (say the house was built in the 50s) you shouldn't have these problems to as much of an extent. You can almost treat oak, maple, or other hardwoods, like a new floor. But if you've got a house that's 65 years plus OR has soft woods like pine, poplar, cedar, spruce or fir, save yourself a HUGE TRUCKLOAD OF GRIEF! Just bang in a new oak floor over the top. I know that poplar is considered a hardwood, but as far as flooring goes, treat it like a softwood.<br /><br />Pet stains, water under house plants and snow tracked in and then allowed to sit under carpet will turn any floor black over time. There is virtually no way to rid yourself of these stains without replacing boards. I have had some success with these problems with oxcalic acid but I needed to apply acid to the entire floor to get an even look and even then, it didn't completely rid the pet stains. Also, the urine that caused the original stain 50 years ago, will amazingly rerelease it's pungent peepee aroma when you hit it with a drum sander. Man, you gotta love it.<br /><br />If possible, post some pics and give us kind of an idea what you're up against. But personally, if I had a 100 year old house and I wanted wood floors, I'd call the old floor my new subfloor and bang in a new floor over the top.
kdfisher
Like others I've been in the business for some time, but only from the installation end. I've been behind a drum sander and on the floor with an edger and believe me it's NOT easy work. What may look good in the DIY eyes upon completion may not be for a prosepctive buyer down the road.<br /><br />Labor rates will vary everywhere and I find $1.00 a square foot for Jersey to be very low. Look around and get several quotes. You'll find some go as high at $4.50 in that region but those guys are booked months in advance and typically use expensive dust containment.
Mdude
Originally posted by Ken Fisher:<br /> Labor rates will vary everywhere and I find $1.00 a square foot for Jersey to be very low. Look around and get several quotes. You'll find some go as high at $4.50...
I was getting $4 - $5 per foot in the late 80s, but it all hit the skids at the end of that decade when interest rates soared and construction came to a halt. That's why I got out. Now it's an absolute buyer's market because virtually all the hardwood flooring crews around here are Mexican. They only need to see it done a couple of times and then they'll try it on their own. Even though the quality will be way low, so will the price and there you go. Now, it's near impossible to find a American hardwood crew around here so you can't even get the high quality if you wanted to pay extra for it.<br /><br />Folks, that's what a "Right To Work" state does for you but hey, that's a subject for a different thread.
John Carpenter
Mdude...I didn't even think about it being pine, but you are right...at that age I bet it is. What a PITA that stuff is to refinish....plus, it will never hold up like an oak or maple floor. The first lady that walks across it in high heels will leave marks all over it.<br /><br />It may sound drastic to those who have never done one, but your comment about using it for a sub-floor has real merit:)However, without knowing the material and condition, it's difficult to give advice beyond the already excellent comments that have been posted.
Bob in Calif.
I just came from a floor refinishing place in the city next to me and I was quoted $4.50 a sq. ft. to sand and refinish the floors, on the house I'm getting ready to sell.<br /><br />I also went to a place that makes counter tops, as I need to replace the one in the above mentioned house.<br /><br />I found a Corian type, with a great color to go with the oak cabinets. This Corian stuff is sold by the linear foot. The sutff I liked (past tense), is the standard<br />24" wide and sold by the foot, legnth wise. I was told the s tuff I like was 30% more, as it was a preium type.<br /><br />I'll say at a premium, this stuff was $290.00 per linear foot. I suspect there is a small margin of profit in that price. :eek: :eek: <br /> <br />...Bob in Calif... <br /><br /> "$ticker shocked In Calif."
