RaceCarRich
- Joined
- May 31, 2015
- 234
Refinishing my B3 this winter. Want it to last. Read all I could.
Almost done sanding by hand and with roloc discs for aluminum on a die grinder. There are some bare spots especially edges, corners, high spots, loose paint, etc. For prep I want to use the Alumiprep 33 & Alodine 1201 or DX-533 & DX-503.
1) Are these two systems exactly the same or is one better?
2) Where is the cheapest source to get them (NJ, US)? They ain’t cheap and it’s seems like a QT is a lot more than is needed and they have a limited shelf life.
3) I know the 533 gets diluted. Are these just brush-on prep products?
4) Will these do any harm to the sanded paint next to the bare spots that I am applying these chemicals to?
I plan on using Zinc Chromate primer and Outdrive paint. I’ve read about using a second primer between the two but most don’t mention it.
Other than gloves and using a mask with ZC primer, any other tips?
Thanks
Thanks
