Regarding the use of treated plywood in boats...
Mark42
Was just reading the sale brochure for my '85 Bayliner Capri 1600 and it says....
"Wood components are preservative-treated, sealed for lasting strength."
Although they don't use the term "pressure treated" it does seem plausable that the wood is presure treated.
At any rate, the wood is treated, and the glass does stick. This from a major boat manufacturer.
reelfishin
Re: Regarding the use of treated plywood in boats...
I just cut up a Bayliner Capri 1600, I believe it was around a 1987 or so. There wasn't much wood left in that boat. If it was pressure treated, it didn't do it much good.
There was no floor left, the stingers had turned to mush and the transom was hollow. The total amount of wood or what was wood in that boat would have fit in a 5 gallon bucket. While I am sure it wasn't very well cared for over the years, it was by far the worst mess I'd ever seen. A tree is what did it in, but the glass and gel coat wasn't too bad other than the fact that a 40" tree trunk fell across the bow and windshield.
I was only able to salvage the trailer, and that needed a new bow stop and tongue.
The wood was actually slimy it was so rotted. The floors were like egg shells, the wood had rotted and fallen out from beneath the glass and gelcoat. It had sat for years after being shrink wrapped, the date on the shrink wrap was 1992, it was sitting under a lean to or carport, the tree brought that down on the boat too. The 40HP Force was also junk. It had sat since Jan. with the tree on it until I took it away. I have to say it was one of the easiest boats I've ever cut up, I crushed it up and pretty much put it all out for the trash in boxes in one week. the only bulk was the seats and motor which was parted out.
I think all those years with that shrink wrap may have helped it rot worse than if it had gotten some fresh air. I suppose is had sort of a greenhouse effect within the plastic covering.
Mark42
I can see why the floors rot so quickly in these boats. The carpet is very dense and can hold water, and the gel coat covering on the plywood is not very thick. I pulled up carpet in my Bayliner and found solid plywood, but I could see the water stains on the gel coat and in places the gel coat had cracked from the wood expanding/contracting.
Thats why I will replace the carpet with a layer or two of glass and then gel coat. That should give the floors another 23 years or so.
I am surprised that the stringers rot, because the ones in my BL are totally encased in glass/gel, at least from looking at the sides via the ski locker in the floor.
