Re: Regular wheel bearing grease on the prop shaft
As long as you remove the prop and grease the shaft once a year, regular wheel bearing grease works just fine. I used it on my sterndrive, which stayed submerged in saltwater all year (Mar-Dec) and never had an issue. If you do not plan to regrease each spring, use the marine grease.
Thanks for the good advice. Just came from Walmart. They had everything I needed. I love that place! They and McDonalds seem to be the only ones posting gains these days.
