rothfm
Ensign
- Joined
- Sep 26, 2006
- 915
Had just accepted via another post that this new to me 1993 140 Looper, was not overcharging (13.2 idle, up to 14.7 Wot).
I was out fishing 20 offshore, and inadvertently moved my batt switch to off, while running! I have a Make-before-break switch. U usually only change with Engine off. But this time I had alot going on in the boat. Wanted to move from batt2 to batt1.
It didnt run long like this, maybe a minute....What gave me a clue was my fishfinder( remember main Batt switch was OFF), for some reason had all streaks on the screen-it shouldnt even have been powered.
Then I heard a "scratchy" sound coming from the remote warning horn...Usually indicative of a Regulator/tach/ground/ Feedback issue through the horn..Remembering this, I shout down immediately, and noticed the switch off.
Put it to #1, restarted and right away notice my idle charge at 12.6( usually is 13.2+) It stays at 12.6 until 1/2 throttle, where it only goes to 13.1...Only at WOT I see it up in the higher ranges of 13.5 to 14.5 depending on RPM.
SO THE QUESTION IS:
1) Am I even changing at idle and low rpm's now?? ( I think not)
2) Whats the likely culprit?
I will be Ohm measuring the stator later....I now these stators are usually varyable from 3-9amps...Could the lower amp portion of this stator be shot etc??
I'm just worried that i do alot of trolling, and do spend nights out there..I will now have to pay extreme attention to what Battery I'm on, if not charging, to preserve a starting battery for a trip home.
SO THE QUESTION IS:
