Re: Regulator testing on the bench
Might is the key word here, because there are different types (some are ACin/ACout, some are ACin/DCout). You may have to switch back-and to with your meter from the two, but the idea of using a variac on the input to simulate a stator sure souinds like a plan. But use a circuit breaker inline on the input of the reg,just in case the regulator is chorted...Or you might end-up replacing the reg and the variac. <br />I got a variac, and will try that myself to troubleshoot one next time.Thanks for the brillant tip
<br />Rectifiers can be checked like a set of 4 diodes.
