I own a 15 footer that needs some work on the transom. Although it seems fairly straight forward on some boats, I'm not sure how to tackle the job on mine.
There is a deep splash well blocking the access to the inside portion of the transom. Do I need to cut out the well then glass it back in after the transom as been done? Do I need to cut out the outer portion of the transom and work from outside the boat?
