Well, if everything goes right this weekend, I should get to the step where I rejoin the top half with lower half. I separated it to replace the transom.
It was originally held together with with pop rivets through the rub rail. It also had a thin layer of mat and resin over the seam on the inside of the boat. This would be hard to duplicate, so I was wondering if there is an alternative method to rejoining the halves?
Could I use 3M 4200 or 5200 and run a bead all the way around the boat before setting the top back on?
Could I use screws instead of pop rivets?
Just wondering what others have done. I know redoing it like it was originally is probably the best way. But there are some areas like in the bow and under the rear splaswell that would be hard to reach to put a layer of mat and resin over the seam with the top back on. Let me know what you think. Thanks in advance.
