Re: Reluctant starting
Could be a million different things.
If giving a bit more gas helps then it's probably not getting enough gas right at start-up.
You should be able to use the accelerator in neutral, sometimes you pull out on the gas handle, or there could be a separate "neutral accelerator"...not used to that small engines...sorry.
There is probably a choke somewhere too - you can try that as well.
This is assuming it starts when you give it some more gas.
Does it need to get the same amount of goosing for a while to run steady - and then runs normal once it's warm?
I think it's pretty common you need an extra splash of fuel when starting cold, all normal.
You just need to find an easier way of providing it.
