saltydogjeff
- Joined
- May 12, 2013
- 145
I recently went through a troubleshooting as to why an engine wouldn't start up while the stern drive was attached. It then turned into not starting while the stern drive was attached. So, now I am trying to put the remote control back together. I am working with a 1988 Mercruiser 470 and alpha one.
I disassembled the remote controls from the dash, and took then apart. I then tried to completely open it up to grease everything, but couldn't get past this.
I then greased what I could, but do not think I got it back together correctly. The spacing down the seam was not parallel all the way through, and the throttle is stuck in this position.
So, below is what I sort of got to, and couldn't get put back correctly.
Is there any way to open up the one plate that is on the first picture? I tried removing the screw on the lever. Also, should I remove the sterndrive to move the shift cable to allow proper installation?
Any help/diagrams/instructions appreciated.
