convergent
- Joined
- May 17, 2010
- 385
I have a Mayfair 26012 bilge pump float switch that doesn't seem to be working. It is switching, and there is voltage through when its up, but for some reason the pump won't come on. It seems to be dropping the voltage down to about 9.5 volts for some reason, so I guess its shot.
Its in a very hard spot to get to and so once I take the screws out I'm sure it will be difficult to get them back... and near impossible to change their location. The switch seems to be attached to the bottom of the hull with two philips machine screws. Do I have to worry about leaks or anything with screws going right into the hull floor? The screws are kind of hidden by the hose in the picture, but you can see that's its screwed right to the hull. Anyone know if I can get a replacement switch that will work in the same holes?
This one looks similar to it... http://www.iboats.com/Johnson-AS888...0220779--**********.128576380--view_id.341201
I have just never messed with screws in the hull of a fiberglass boat before and don't want to introduce a leak inadvertently. I know the screws don't go all the way through the hull since they don't come through the bottom of the boat, but I have no idea how thick the hull is. If I need to relocate the holes, what's the safest way to do this?
