sugardaddy
- Joined
- Jul 12, 2008
- 4
So as to not let the summer end without using my pontoon boat, I decided to buy a used Johnson 60HP motor to replace my problematic Johnson 40 HP. Actually I had to buy a Bass Boat with hull problems but the engine was good.
This weekend, I removed the used 60HP motor from the Bass boat. I had a very difficult time removing the steering rod from the Cable guard tilt tube. I had to use a large hammer and a rod to drive the rod out of the tilt tube. As I recall, I had similar difficulty in removing the steering rod from my old 40HP last year. I found an old post that said to loosen the starbord side nut from the tile tube. I did that but the removal was still very difficult. Should I have done more? Should I have removed the tilt tube altogether?
I am going to have to put the rod back in next week. With the difficulty I had in removing it, I wonder how I am going to get back the rod back into the tube. With a hammer and rod removal was possible, but for re-installation I don't see how I will be able to force this rod back into the tilt tube.
Can someone give me some advice or a reference to a document that I can use to see how removal install of the steering rod should be done? Thanks in advance..
