Re: Remove Bell Housing - Bravo III
Tapered Insert Tool 91-43579 (Found on ebay for $25) to remove water hose insert.
Yea, your going to need that one.
U-joint bellows sleeve removal tool P/N 919818169 (can't find this one)
Pry the old one out with a screwdriver and install a new one. Besides a new one comes with the new bellows. And I know your won't be reusing an old bellows with all that work.
Sleeve Installation Tool (U-joint Bellows) 91-818162 (can't find)
I made one out of plywood. Made a disc the same size as the OD (or slightly smaller) of the ring with another plywood ring inside to keep the ring centered.
Then drilled a hole in it and used the alignment bar in the center of it to hold it, and push it.
Hinge Pin Tool (P/N 91-78310) (found on ebay for $16)
1/2" allen will work, unless it strips, then the outcome (parts and labor) will be higher than the tool.
PS: Your local Merc dealer can get any of those tools for you.
