remove gimbal housing studs?
JASinIL2006
Hi, I need to remove some corroded gimbal housing studs (the four lower studs for a Alpha one Gen II) -- new ones are en route. Anything I need to do to pull them other than give them a good soak with PB Blaster? I really don't want to mess up the gimbal housing, so if anyone has any tips for easy removal, I'm all ears... er... eyes!
Thanks,
Jim
Re: remove gimbal housing studs?
Ayuh,... Just double nut 'em, 'n run 'em out....
An Impact helps, but not necessary...
JASinIL2006
OK, thanks, I'll give it a shot.
What about installing the new ones; same thing in reverse? Any threadlocker needed?
Jim
achris
More fish than mountain goat
Jim
Just for safety I'd put a bit of Loctite 222 on them.
If the old ones are really tight, try heating them up to break the seal.
JASinIL2006
Thanks, they came out with just a little "encouragement." I was just a bit paranoid about snapping one after I broke a lag screw in the motor mount when pulling the engine last Fall.
Jim
