if the boat has not had any maintenance for a while and the fasteners are corroded in place, it will take a bit of time. not sure how effective Boltex is compared to Kroil or PB blaster on this side of the pond, however you are working against galvanic corrosion from many years. This is where the finess and care come in place. you may have to alternate between propane torch and cooling with freon spray.
you may most likely snap off a bolt, at which point, you will be forced to drill, extract, retap, etc.
