how do you remove the lower unit on a 70hp johnson?<br /><br />Lee
M mlslocks Seaman Apprentice Joined Mar 30, 2003 Messages 49 May 23, 2006 #1 how do you remove the lower unit on a 70hp johnson?<br /><br />Lee
O ob Admiral Joined Aug 16, 2002 Messages 6,992 May 23, 2006 #2 Re: remove lower unit ? Remove "all" of the necessary bolts(including the one under the trim tab) from the lower unit to mid-section joint after disconnecting the shift rod from under the lower carb area.
