Remove One Exhaust Bolt - Need to redo all bolts with new gasket?
FluffyChicken
I accidently misplaced my remote oil system when swapping my 5.0gxi last summer so I ran the boat with the oil filter installed direct to the block. Thankfully I shouldn't have too much issue getting to the filter. I ended up procuring a remote setup over the winter which is in nice shape and I'd like to install it this spring but the one hose retainer is mounted though the forward most exhaust mani bolt. Is it ok to remove and replace just one bolt and retorque or should I avoid this and just ziptie hoses to the one coolant hose and/or dipstick? I'd like to keep it the way VP intended but If i need to get a new gasket and retorque all the bolts i'd be ok with doing it a different way.
Thank you,
BRICH1260
I would think that you would be ok removing and reinstalling the bolt. The only thing I see you risking is shearing off the bolt and then having to remove the entire manifold.
FluffyChicken
Haha yeah that sounds like a great way to ruin a Saturday.
cptbill
Those riser gaskets are are a contentious enough , if where mine I'd spring for a new gasket
pulling 1 manifold bolt is not a problem
that 55# of cast iron wont move enough to effect the clamp on the gasket
