1989 Johnson 40HP
I removed the VRO & replaced it with a mechanical/vacuum fuel pump.
I disconnected 3 wire harness from VRO to engine wiring. There are two wires from the oil tank (i cut them to get the tank off) one I believe went from the tank to engine ground & the other to the heat sensor (tan wire). Should I connect the tan wire to the other tan wire in the main wiring harness?
The alarm comes on immediately when I start the engine.
Thanks!
Thanks!
