Removeable bimini
fishngator
I have a bimini top that I would like to be able to remove in minutes, without unscrewing any hardware. I saw a removeable set up in a magazine once... anyone know anything about where I can find more information on something like this??
D
DJ
Guest
Re: Removeable bimini
Gator,<br /><br />It's as simple as getting "thumb screws" for your attachment harware.
D
DJ
Guest
gator,<br /><br />Good suggestion by Jolly. As long as your hardware will take the pins. If not, you can drill them out.
andrewkafp
Sorry... :D I misread the post..<br />Thought it said Bikini... :D :D
Dhadley
I use the pin set up too. We actually have two locations for the top, depending on use. It can be moved or removed in seconds. And the pins are attached to the top so there is nothing (screws and nuts) to lose. <br /><br />Believe me -- I would lose 'em.
Solittle
Mine is mounted on slides so that all I have to do is unhook the two front straps and slide it all the way aft out of the way.
